VU Duo Tuner B Problem
  • SGTFlipFlop
    • Sep 2009
    • 1002
    Righteo, Got my box, set it up ViX image thought all was working OK, Until I thought I would try the twin tuner out.
    Started recorded ITV on tuner A, Perfect all working then when I go to change channel on Tuner B I get 0% SNR on all HD channels but on SD channels I get a signal (About 40% SNR) but very blocky which clears up if I stop the recording on Tuner A, Is there a way just to test each tuner on there own? and does anyone have the same problem as me and know a fix?
    Help meeeeeeeeeeeeee
  • dell_xps
    • 2558
    Whats yer setup in tuner config m8 ?, have you got tuner setup on loop through ?
    • SGTFlipFlop
      • Sep 2009
      • 1002
      Got it sorted, The second feed cable had shorted out, Pulled it back a few cm and it worked perfect
      • birdman99
        • Mar 2010
        • 19
        is loop through the correct setting for tuner b on motorised dish setup duo twin lnb?
        • RuberDuck
          • 1724
          no set it to equal to tuner a
          • tichmc9
            • 60
            whats the correct settings for tuner configuration got duo clone but only get 200 services tuner a set to single then simple ?
            • dell_xps
              • 2558
              Should find about 1042 or there abouts m8, got it set to Astra ?
              Away the bears ;-)
