vu solo playlist problem
  • cactikid
    • 12017
    my recordings are on the vu+duo and i look at them on the solo elsewhere,i have a big list on the playlist which have been deleted off the duo but cannot see how to remove or erase them once viewed on the solo.any ideas cheers?
  • dell_xps
    • 2558
    Does pressing the menu button on the file do anything m8, just a stab in the dark as I dont own a solo :-)
      It should be the same way as your Duo both E2, press menu switch to Play list and delete
      • cactikid
        • 12017
        its different on the duo as i can delete it direct with red button and its gone,on the solo i tried the menu button on the playlist and that now gives me many choices,so delete playlist and now blank,cheers guys.
        • den169
          • Nov 2011
          • 12
          They delete with the red button on my solo.But then go into a deleted folder and have to be deleted in there aswell.
          • cactikid
            • 12017
            if the recording were on the solo the red button would, but i am only using the solo to access the duo drive elsewhere through the network.
            your solo probably has a usb hard drive attached where mine has not.
