Some channels have corrupted picture
  • vuduo
    • Apr 2012
    • 56
    hi guys,
    my vu+ duo has been running fine, but now i have woken up to another issue. Some channels work fine, but quite a few are corrupted. The picture can be in different colours (blue) or i could have horizontal lines on some channels.
    If i press the epg button, i can see the picture perfectly in the top-right hand corner of all channels, so this can't be an issue on the other side and has got to be box related.
    If i change to a freeview channel and then change back to the corrupted channel, then that fixes the issue.
  • dell_xps
    • 2558
    Have you got it set to 50Hz or 60Hz or multi ?, also make sure its set to PAL !! ( try 50Hz then 60 Hz etc etc)
    Try a different HDMI lead also m8 :-)
    • vuduo
      • Apr 2012
      • 56
      Dell m8! Where have you been pal?
      I've seen ur post a little late and since then I've reflashed the box using a backup I made on the usb 2 weeks.ago and all is fine now, thanks!
      Let me know when you'll be on :-)
      • dell_xps
        • 2558
        On nightshift again m8, catch ya Wednesday at some point ok :-)
        • vuduo
          • Apr 2012
          • 56
          No worries..tc
