OE-Alliance OnDemand player
  • RuberDuck
    • 1724
    #16
    Originally posted by lincsat
    The version loaded from the feed did not have ABC iview but the download from the GIT is now compatible with BH2.0.2, so just extract the files from the archive and FTP into the appropriate folder then restart enigma.
    Any news of when they will get past the Geolock for ABC?
    unfortunately no, we have spoken to the TUNLR devs about the possibility of using their service for this but they have no plans to expand their servers to cover Australia, so for the moment the only solution is to take out a paid VPN account if you want to access ABC iview section from out side of Australia.
    we also have a working demand 5 plugin but we may have to shelve that as all content uploaded to their servers after august is DRM protected and because of that it cant be played via the STB. although were looking to see if there is a way around this, i'll keep you informed.
    and yes it is very good news that BH have cloned the OE-Alliance OnDemand GIT as this now allows far more inter image compatibility than before.
    • RuberDuck
      • 1724
      #17
      Originally posted by dougm1970
      my rte player on ondemand doesnt play....just freezes.....i see this a LOT over and over again in the log....what does it mean ??
      gst_element_query_position failed in getPlayPosition
      also...to explain more...i can get the menu's and listings of the videos on rte player up fine...it is only when it tries to play them...the player is stuck on 0.00 and doesn't play anything...and pressing stop gives the vix logo spinning and it takes around 7-8 minutes to go back to the previous screen...the listing of videos on rte player.
      the rest of the ondeman plugin is fine...bbc iplayer, tv3 player etc..no issues.
      also other streaming plugins like icefilms have no issue
      sorry but were going to need a wee bit more information than that mate, such as what exact image and build number your using and your geographical location etc. also we really would need to see a debug log from these times as this would greatly aid us in finding the problem.
      • dougm1970
        • Mar 2012
        • 103
        #18
        thanks for the reply.
        i uploaded the log file here rather than post it as it would be long..
        http://ge.tt/6SH86Hc/v/0
        vu+ duo
        vix 3.0 build 632
        usb flash 1gb for epg and 96mb swap
        internal 160gb for recorded files.
        have tried without drives attached.
        my friend has same box...same image, build etc and his rte player plays fine.......we have the same plugins installed...nothing different that i can figure out...except different isp's
        i am asking on other forums too
        on the router...last night..i changed the dns settings from my isp to google dns (8.8.8.8) but still same.
        everything else that uses our broadband through the same router is fine.....and everything else that uses internet connection on the box is fine....
        when doing a broadband speedtest from my laptop wirelessly i get typically 45ms ping and 7.90 up and 7.90 down (i get same up as down on the connection i have)
        i have turned firewall off on the router.
        even things like icefilms work perfect on the vu+
        rte player works perfect on laptop and ipad.
        • dougm1970
          • Mar 2012
          • 103
          #19
          what dependencies does this plugin use to play the rte player ?....just wondering if another file / plugin / setting could be effecting mine.
          (i'm posting this on a few forums)
          • belfastchris
            • Mar 2013
            • 11
            #20
            can anyone help with my on demand player, i installed it last night on my VU+ duo original with Vix image, FTPd the files to the directory stated then ran the telnet command - the player restarted but when i go into the plugins menu i get - 'some plugins are not available:extentions/ondemand/ (no module named simplejson)'
            then once i exit the error message there is no reference to the plugin in the plugins list?
            if the plugin has failed and cant be fixed how can i safely remove it?
            • septicsmurf
              • Feb 2012
              • 401
              #21
              If you're running vix, why not just download it from the feeds?
              • belfastchris
                • Mar 2013
                • 11
                #22
                Doh Ive never used the feeds before (only had the box a week) thanks for that' brill app!
                Sent from my AT100 using Tapatalk 2
                • septicsmurf
                  • Feb 2012
                  • 401
                  #23
                  If you have any movies you can try out the movie browser plugin as well.
                  Really great plugin which scrapes all the movie info, artwork, etc.
                  Takes some getting used to and is very picky with movie names, but once it's sorted it is great.
                  • RuberDuck
                    • 1724
                    #24
                    24.03.2013
                    -[OnDemand] BBC iPlayer Play Stream Update
                    -Currently if we don't find the preferred stream quality or lower an error message is thrown and nothing is played even if a playable stream is found.
                    -We are now going to play the available stream now anyway even if it doesn't match the preferred quality setting but a message will be displayed to notify you that this has happened.
                    01.04.2013
                    -[OnDemand] add fallback for images that do not have 'SCOPE_ACTIVE_SKIN'.
                    20.04.2013
                    -[OnDemand] update GUI for main menu.
                    27.04.2013
                    - [OnDemand] Fix OpenUitzending gemist (thanks Aux99).
                    01.05.2013
                    - [OnDemand] fourOD Feeds Update- The feeds for fourOD have changed to need to update the plugin to use
                    - new menu item tag.
                    • sabbacool
                      • Feb 2013
                      • 48
                      #25
                      How do I get 4od back?
                      • RuberDuck
                        • 1724
                        #26
                        you cant. it was removed because changes CH4 made to the way they stream broke the plugin, we along with the XBMC dev on who's plugin ours was based have called it a day until a new fix or solution is found.
                        • RuberDuck
                          • 1724
                          #27
                          -09-06-2013
                          -[OnDemand] bbciplayer.py
                          -updated swfurl links for bbciplayer. ( Thanks to Digidude for the fix.)
                          22.07.2013
                          -[OnDemand] Update tunlr DNS server settings ( Thanks mickd for the heads up )
                          25.07.2013
                          -[Translations] NL Update, Thanks Rob.
                          13.08.2013
                          -[Translations] ET-Update, thanks Rimas.
                          15.08.2013
                          -[OnDemand] Remove 4OD and OUG
                          -4OD can't currently be fixed and OUG is not currently being maintained so they are being removed until a time that a fix has been made for either.
                          02.10.2013
                          - [OnDemand] iRadio
                          - Adding a new Internet Radio plugin to OnDemand
                          - Radio Sources from:
                          - SHOUTcast
                          - Tunein
                          many thanks to mcquaim ( MAC ) for all his hard work and bringing this update.
                          • lincsat
                            • 1228
                            #28
                            Do you have a location for the latest revisions? The GIT link I have hasn't been updated since April.
                            • RuberDuck
                              • 1724
                              #29
                              This is about the OE-Alliance ( original ) version not the others, i'm surmising your talking about the BH git which has not been updated for many many months.
                              https://github.com/oe-alliance/oe-alliance-plugins/commit/e2bdf06831b27dd8937fd14aea9ef0ed89de7e29
                              • lincsat
                                • 1228
                                #30
                                Yes M8 - thanks
