Green screen up saying error's?????? what do i do!!!!!!!
  • pokey1974
    • Mar 2013
    • 36
    green screen has came up with these errors dont know what it means saying STB encountered a problem ive no idea what this is.....help required dont no what to do
  • scottj130208
    • Apr 2011
    • 323
    If it green screens as soon as it boots up you woul have no option I would of though but to re flash image have you made a back up of your current image and settings
      I am afraid we cannot help you without a more somewhat detailed explanation of how the error occurred or perhaps you could post the error logs themselves
      • pokey1974
        • Mar 2013
        • 36
        i was trying to take the crossepg of usb then the green error sreen came up saying STB problem and needs to be restarted,please send log file.....really dont know what to do now
        • pokey1974
          • Mar 2013
          • 36
          i couldnt tell you mate if all was backed up dont really know if not what do i have to do?
          • scottj130208
            • Apr 2011
            • 323
            Flash by usb with the image you had on before it started green screening if u have a sea lion make sure this is backed up unless you have this on your pc or even written down
            • pokey1974
              • Mar 2013
              • 36
              the box came with image on it so i dont have nothing mate so i am up the creek without a paddle because i really am stuck dont no what to do now
              • scottj130208
                • Apr 2011
                • 323
                Have a look on the box on the left hand side does it have a white sticker on it if it does its a clone and you will need to go to vu plus hd.tv to get a clone safe image either blackhole or vix image then copy to usb pop in front usb and re flash the box
                • pokey1974
                  • Mar 2013
                  • 36
                  yeah its a clone mate got image on usb put it in now its been saying starting for about 10mins with a red light thats it should i try vix image or what would u do in this situation?
                  • scottj130208
                    • Apr 2011
                    • 323
                    I personally use vix as use to it epg is 7 days and very stable have a try with vix make sure you format usb to fat 32 then copy image to root of usb insert in box at front whilst box is switched if then switch on also you may need to try a few usb sticks as the vu duo can be a pain with certain usb sticks it should say reading then programming then erase then flashing takes around 3 mins top to flash wait till it says finished then unplug usb switch it off from back switch back on and fingers crossed will be flashed perservere u you will get there
                    • pokey1974
                      • Mar 2013
                      • 36
                      all done but froze on restarting red light on and it just says starting but nothing happening
                      • scottj130208
                        • Apr 2011
                        • 323
                        You may need to try a few images on it do you know which clone version it is should have a sticker on the back either v2 or v3 also when switching on at back switch it on then off after 3-5 seconds then back on again they are a pain to boot sometimes with mine I have to do this so it boots up ok otherwise mine gets stuck on starting if yours is a v3 have a look on vu plus hd .tv and make sure you download a v3 image also all v2 images will still work as long as its s v3 if its a v2 then you can only use v2 images on it
                          Try Blackhole 1.7.2 thats what most of the clones use to come shipped with its a good image and can be downloaded from most places, switch the box off and try either the front USB or the back ones until it flashes.
                          • pokey1974
                            • Mar 2013
                            • 36
                            its a v3 mate still getting nowhere with this will look on the site now
                            • scottj130208
                              • Apr 2011
                              • 323
                              There a quite a few v3 images on the vu plus site also make sure usb is formatted to fat 32 and only vu files are on the usb also if u have a hard drive connected disconnect it 1 st before flashing
