Solo 2 tuner b problem
  • konatist
    • 392
    Fitted a dish when i moved a few weeks ago all was fine now, on my tuner b im getting nothing when i go to sat finder the signal is strong on A, but on tuner B it jumps to 70 for a millisecond then bk down to zero checked wires all seems fine
    You might have to reflash the image
    • konatist
      • 392
      Cheers digi ill try that i tried to rescan but was just the same
      • konatist
        • 392
        Just finished a reflash and still no joy can you recommend anything else digi
        • cactikid
          • 12017
          you have done the obvious got 2 cables connected,change them around and you set up tuner config also?
          • konatist
            • 392
            Yeah shot gun cable, and just swapped em around seems to be the wire should have really checked that by swapping em around yesterday instead of just checking the connections trip up the ladder bit of a fiddle and sorted thanks digi and cact for both your help
              Originally posted by konatist
              Yeah shot gun cable, and just swapped em around seems to be the wire should have really checked that by swapping em around yesterday instead of just checking the connections ha ha
              At least you found the cause of the problem sooner rather than later
