VU+ solo2 out of range
  • lamplighter
    • Jan 2013
    Hi. My VU+solo2 box seems to have stopped working with the HD lead.It only shows out of range on all resolution settings. It was going perfect up to yesterday.
    When it was switched on,the screen showed green and then light red for a short time and since then it only displays out of range.It is going ok if I use a scart lead.(HD lead is working ok)
    I am using the latest OpenVix image which I reloaded last night.
    Any help would be much appreciated. Thank you.
  • DOUGALMCD
    • May 2011
    • 3229
    Have you checked your av settings haven't changed. setup/system/av settings. Try box on another tv to rule out faulty hdmi. Try another image
    • lamplighter
      • Jan 2013
      Thank you DOUGALMCD. It turned out to be the HD input on the telivision that has gone faulty. When I changed the lead to another one everything worked perfectly.
