Vu+ Mini Solo
  • dave1976
    • Feb 2013
    • 4
    Vu+ Mini Solo
    does anybody know how to flash the vu solo mini i have a box that keeps going back to set up stage and i dont know if you can set up by usb or not. can someonr please help me
    thank
  • portbhoy
    • 717
    Look for guides for the cloud ibox or VU Solo, do your research tho and dont just grab the newest firmware out there.
    • beeb2412
      • 52
      thank
      Stick your image on a Fat32 formated usb stick in a "vuplus" folder on the root of the memory stick.
      Make sure that the box is off and plug usb into your reciever
      Once usb plugged into your reciever then turn the power switch to "ON" position
      Now you wait as the image is flashed on the box the LED on the front of the box will begin to flash.
      This can take up to 3 minutes.
      Once it is complete the LED will begin to blink blue which means the image has be flashed.
      Turn the box off and remove the usb stick and switch the box on and you will be ready to go!
