VU+ Solo 2 stuck !!!
  • BrunoJ
    • Jul 2013
    • 141
    Hi guys, just got a VU+ Solo 2 and after update the image all i get is the power light on nothing else. Every time i press the power light goes brighter !
    Try flash by USB, also try the VU+ Util and still no joy.
    Does any one had this problem before ? Any help be great.
    Thanks in advance.
  • DOUGALMCD
    • May 2011
    • 3229
    What update an online update what vu solo 2 do you have? Clone version I assume you may have to replace chip. What image where you on? May get you more answers.
    • Jimdefruit
      • Apr 2012
      • 33
      If its a genuine box, try removing the LAN cable and rebbot then once it is running ok, plug the LAN cable back in. I found this problem after an update on my Duo2.
      Sent from my crystal box, using my cat's whisker.
      • cactikid
        • 12017
        any time i update image ,it is fresh flash with no backups used,and by trying to online update might not be compatible with older images.also note always check first if there is a new bootloader .
        you need to know if box is a clone as using newer images may kill them.
