tune failed
  • ringryan
    • May 2015
    • 32
    tune failed
    put my dish back on the wall be working ok but freezing quite a bit now its dark its comming up tune failed
    any ideas you good people
  • DOUGALMCD
    • May 2011
    • 3229
    First of all did you fit it correctly? I've got to ask
    Check you've got latest channel list.
    Check the fittings at each end of cable are correctly fitted.
    Check dish is aligned properly and is not obstructed.
    Check skew on lnb.
    If that doesn't work.
    Try your box elsewhere to check it works correctly.
    • ringryan
      • May 2015
      • 32
      it now looks like my dish is out as i have moved it up higher about a foot and a half will sort out tomorrow
