hi all, set up vu duo with black hole 151, downloaded Vhannibal E2 Motor the latest one, put them on the image and 16e was working ok, but rebooted and when i go to 16e all the channel listings are not hilighted, when i set it up in the tuner config it said 16e, but know it says 15.8, new to sky so it may be obvious to somebody, hope somebody could tell me what i did wrong, thanks
problem with 16.0e
Then modify it back to the correct 1 as 15.8 is the correct 1 m8, . Especially with the sat being weak anyway, And it was obvious that his bouquet was wrong, Don't forget m8, load the bouquet then change your tuner configuration after. so what you trying to prove.Last edited by satmannwest; 3 May, 2011, 20:02.Comment
again that was the point. when the satellites.xml was referencing 15.8 it was not working, now he has modified it to reference 16.0 it works for him. and yes i know the correct designation of the satellite in question.Comment
