VTI Epg
  • nowuckinfurries
    • Aug 2009
    • 111
    VTI Epg
    Anyone know how to get 7 day Epg on VTI Image on Duo?
    Can't find answer anywhere and stuck with now and next.
    Nwf
  • dell_xps
    • 2558
    Nwf
    Cross epg in plugins, let it download,
    set it up to download each day at a time that
    suits you.
    Not in the house at the mo, but will give you it in more
    detail when I get home if you are still stuck.
    Look for rytec uk, somewhere in plugin, download that see how
    it goes.
    • nowuckinfurries
      • Aug 2009
      • 111
      Thanks Dell.
      Further to that
      Here's the answer if anybody else needs help
      Setup Cross EPG follow this
      1. Start crossepg from the plugins menu or in some cases from the menu button enter the configuration tab. If you see your hdd or usb on top option your ok USB is preferred now select yes to all options, turn scheduled download on and then choose a time then exit and select xmltv providers.
      2. Scroll and select the EPG's you want do one at a time and press the yellow button to do a manual download now.
      3. After the download completes press the info button and then yellow for single it should now show you a seven day EPG
      Nwf
      • dell_xps
        • 2558
        Doddle m8 :-)
