Hdd for vu+ duo
  • tool37
    • 139
    Hdd for vu+ duo
    Hi all, thinking of installing an hdd in my vu+ duo, can anyone recommend a make and model, looking at 1tb, but read about heat issues and compatiblity, any ideas welcome thanks
  • tool37
    • 139
    Samsung HD103SJ SpinPoint F3 1TB 7200RPM SATA II 3GB/s 32MB Cache OEM, looking at this drive, price ?40,
    • lincsat
      • 1228
      I go for the Samsung Eco Green with 5400RPM spin speed, they are supposed to be a little cooler.
      • tool37
        • 139
        Thanks for the reply, will search for one now, is it hard to install, running bh 1.6.5.
        • lincsat
          • 1228
          Quite easy, connect the HDD to the caddy using the supplied screws and Rubber shock absorbers, connect power and SATA.
          When you power up the box, you need to initialize the HDD from Menu - settings - system - Harddisk. You can then configure CrossEPG to use the HDD and set a swap file if required.
          • dell_xps
            • 2558
            I installed a 1TB SAMSUNG HD103SJ SATA F3, ?40 maybe cheaper now, not had 1 bit of bother with it.
            • tool37
              • 139
              Thanks dell, will order now, just another question, have motor setup on tuner A (19-16-13-10-7-4-0.8) setup on it, fixed dish on tuner B(28) setup, can I still record from 28 and still be watching 28 or would I have set it up on tuner A aswell
              • alec
                • 345
                If you have B tuner configured correctly on a fixed dish Sat, you should be able to record the programs on that sat, independant of what the motorised dish is pointing at on tuner A.
                • tool37
                  • 139
                  I only have 28 on tuner B, can I watch 28 on tuner B and record tuner B at the same time or will I have to setup 28 on tuner A ?
                  • dell_xps
                    • 2558
                    I would say yes you should be able to do that m8.
                    HTH
                    • tool37
                      • 139
                      HTH
                      Thanks m8, just ordered the drive ?42 and set up 28 on tuner A aswell, will have a play when the drive lands, dell did you format the drive before you installed it in the box or when you put it in. Thanks again m8
                      • RuberDuck
                        • 1724
                        no need to format it if it's brand new. however some people do have problems initializing HDD's with any thing but the original image. i didnt have any issues my self with a Uno and a 2.5 hdd i installed using VIX but some do.
                        • dell_xps
                          • 2558
                          If you check out a tut I did when I first got my VU+ duo you'll see that you had to have the original VU+ image on it, format/initialize HD then re-install the Vix image.
                          If it doesn't format straight away, you'll have to do as above m8 :-(
                          HTH
                          • lincsat
                            • 1228
                            They initialize OK for me using a recent Blackhole image
                            • taff2412
                              • May 2011
                              • 18
                              where do you buy the 1tb for 40 ?
