Cannot connect to Vu+ Duo now i have flashed images??
  • Kennyken
    • Apr 2010
    • 78
    Basically flashed my Vu Duo from dream elite to dreambox uk image.
    No when i try and connect via dreambox edit to change bouquets it says it cannot connect via ip address.
    I have all the correct ip's, usernames and port numbers in dreamboxedit just wont connect now.
    Is there an option in the dreamboxuk image that prevents this?
    Cheers
  • andy211081
    • 575
    you seem to know what you are doing but have you defo checked the ip addy on the box? via the menu - setup- network-adapter settings?
    Ladies and Gentlemen, this is your captain speaking. I have the only gun on board. Welcome to Con Air.
    • Kennyken
      • Apr 2010
      • 78
      i have yes many times....Any ideas?
      • andy91
        • 3583
        Sounds like you have wrong ip address somewhere.
        Ping the box through web browser.
        Put the ip address in you think is correct into web browser and hit enter,if its correct will come up with dreambox web control.
        Andy.
        • Kennyken
          • Apr 2010
          • 78
          Andy.
          Ive done this mate...comes up with the webcontrol.
          also the ip address works with a ftp program.
          Could it be a problem with dreamboxedit?
          • RuberDuck
            • 1724
            you could try starting a telnet session the enter the user name ( root ) then type
            passwd
            exactly as i have spelled it. this should kick in a password reset enter the password then hit enter and do it again, dont worry if you dont see a onscreen prompt between entering the password both times it will still work.
            • andy91
              • 3583
              How bout Dreamset you could try that as an alternative.
              Andy.
              • Kennyken
                • Apr 2010
                • 78
                it wont connect also....when i put the ip address in my browser it opens webcontrol but wont load any contents ie programs and radio.
                • RuberDuck
                  • 1724
                  go into the network page on the receiver and see exactly what it says there. failing that you may need to reflash with a new image or even with the same one. also make sure that the FTP server is actually active on the box.
                  • andy211081
                    • 575
                    try dreamboxedit with administrator privs and try a new version of dreambox edit.
                    • cactikid
                      • 12017
                      would it be as simple as a reboot to reconnect
                      • jdeer577
                        • Dec 2011
                        you need the new firmware m8
                        • tomhick024
                          • 559
                          I had issue with vu+duo using older version of Dreamset!!
                          When i d/l the latest version it worked fine after that. try using dreamset. double click on setting and use test config and see what happens!!
                          Whatever!!
