VU+ UNO / DUO CLONE QUESTIONS & ANSWERS ONLY.
help setting up motorised dish
Hi guys i have just got my clone through but i'm having problems and need some help
on occasion the motorised dish gets lost and stops working its brand new and would like to set it up with diseqc 1.2 and not usuals
to see if the problem resolves it self the motor is a lsat Dark Superior DiSEqC All Metal Geared MotorComment
Which clone do you have buddy a Duo or Solo
Have you got any internal hard drive installed or maybe external, to rule out the motor i would try the receiver bare so to speak no HD's or USB sticks attached so that all the PSU is powering is the box itself Motor and LNB.
You may not want to entirely up to your self maybe try BH 1.7.2 as the later images 1.7.3 onwards are full of bloatware crap like 'Universes'. 1.7.2 was probably BH last best untuoched image for the Duo Clone
Regards
thanks for that i may try 1.7.2 but not sure how to flash these boxs give me a dreambox anydayHave you got any internal hard drive installed or maybe external, to rule out the motor i would try the receiver bare so to speak no HD's or USB sticks attached so that all the PSU is powering is the box itself Motor and LNB.
Regards
i do have a cross over cable and nul modem though?Comment
Easier than that mate just download the image extract so you just have the folder which says 'vuplus' put it on a USB stick in the front power off and then on again and away you go.
Images your looking for are labeled 'bm750'
