hi as anyone ever setup and used oscam, currently running cccam but certain services not working, was told to use oscam, but never used it before, and dont have a clue how to set it up, is it the same as cccam or are the settings different, thanks
oscam help
I guess the standard Pick TV and Premier Sports which are not shown when using CCcam.
I did manage myself to get this to work, but it took some time. The best guide I found was: (follow it very carefully it shows examples of using either cccam or newcamd as the client)
Oscam setup
oscam.server
[reader]
label = reader1
enable = 1
protocol = internal
device = /dev/sci1
services =
caid = xxxx
boxid = xxxxxxxx
detect = cd
mhz = 500
cardmhz = 600
ident =
group = 1
emmcache = 1,1,0
blockemm-g = 1
lb_weight = 100
oscam.conf
[global]
logfile = /tmp/oscam.log
disablelog = 1
disableuserfile = 0
usrfileflag = 0
clienttimeout = 4
fallbacktimeout = 1
clientmaxidle = 60
bindwait = 10
netprio = 0
clientdyndns = 0
resolvedelay = 10
unlockparental = 0
nice = -1
serialreadertimeout = 1500
maxlogsize = 50
waitforcards = 1
preferlocalcards = 1
saveinithistory = 1
readerrestartseconds = 5
lb_mode = 0
lb_save = 0
lb_nbest_readers = 1
lb_nfb_readers = 0
lb_min_ecmcount = 5
lb_max_ecmcount = 500
lb_reopen_seconds = 900
resolvegethostbyname = 0
[monitor]
port = 988
nocrypt = 127.0.0.1,192.168.1.1-192.168.1.230
aulow = 120
hideclient_to = 0
monlevel = 3
appendchaninfo = 1
[newcamd]
key = 0102030405060708091011121314
port = 34001@xxxx:000000;34002@xxxx:000000;34003@xxxx:XXX XXX;34004@xxxx:000000
allowed =
keepalive = 1
mgclient = 0
[webif]
httpport = 8888
httpuser =
httppwd =
httprefresh = 50
httpallowed = 127.0.0.1,192.168.1.1-192.168.1.255
httphideidleclients = 0
httpreadonly = 0
oscam.user
[account]
user = Vu+Duo
pwd = dreambox
disabled = 0
expdate =
group = 1
hostname =
uniq = 0
sleep = 0
monlevel = 3
au = 1
services =
caid =
betatunnel =
ident =
cccmaxhops = 10
keepalive = 1
numusers = 0
penalty = 0
CCcam.cfg
N: 127.0.0.1 34001 Vu+Duo dreambox 01 02 03 04 05 06 07 08 09 10 11 12 13 14
N: 127.0.0.1 34002 Vu+Duo dreambox 01 02 03 04 05 06 07 08 09 10 11 12 13 14
N: 127.0.0.1 34003 Vu+Duo dreambox 01 02 03 04 05 06 07 08 09 10 11 12 13 14
N: 127.0.0.1 34004 Vu+Duo dreambox 01 02 03 04 05 06 07 08 09 10 11 12 13 14
PROVIDERINFO FILE : /etc/CCcam.providers
CHANNELINFO FILE : /etc/CCcam.channelinfo
CAID PRIO FILE : /etc/CCcam.prio
SERVER LISTEN PORT : 0
newcamd.list
CWS = 127.0.0.1 34001 Vu+Duo dreambox 01 02 03 04 05 06 07 08 09 10 11 12 13 14 lan cardserver
CWS = 127.0.0.1 34002 Vu+Duo dreambox 01 02 03 04 05 06 07 08 09 10 11 12 13 14 lan cardserver
CWS = 127.0.0.1 34003 Vu+Duo dreambox 01 02 03 04 05 06 07 08 09 10 11 12 13 14 lan cardserver
CWS = 127.0.0.1 34004 Vu+Duo dreambox 01 02 03 04 05 06 07 08 09 10 11 12 13 14 lan cardserverComment
