Hi, having a problem with mgcamd, running two lines one on mgcamd and one on cccam, lines work ok, but when I switch from mgcamd to cccam, line appears offline and router management software on pc says router offline, then I have to restart the router, it does not happen when you switch cccam to mgcamd only the other way, have belkin router, have tried everything, but problem is still there, only using mgcamd because other line has certain things missing and when I put them together limited line overrides the other one, any ideas welcome, thanks
