clock change
  • jordie
    • Dec 2011
    • 13
    clock change
    Since the clocks went forward an hour my epg is out, the timer on the info bar is correct but the epg is an hour behind, can any help?
  • showboat
    • Feb 2011
    • 14
    I have the same issue, happened last time clocks changed as well and i cant remember exactly how i fixed it.
    There were loads of thread about it as well.
    Think i might have had to delete all the epg info from the box using an ftp program and do a manual update, pain in the ass!
    • 03ahmads
      • Jun 2011
      • 150
      Change the timezone to a different one, save it, then change the timezone back again. Did the trick for me.
      • jordie
        • Dec 2011
        • 13
        cheers that worked, i did it myself by chance earlier
        • RuberDuck
          • 1724
          you could also initiate a Telnet session then issue the init 4 command to kill enigma. now FTP to the receiver and delete any and all epg.dat files you can find, once done go back to the telnet session and issue the init 3 command to wake enigma. once you have done this re-download the epg and the time should now be correct.
