I'm trying to setup an NFS server on my duo but cant find the /etc/exports directory
  • tmontana
    • Jun 2026
    hey guys,
    im trying to setup an NFS server to stream content from my duo to my solo.
    Ive read that the share configuration file is located at /etc/exports and that it must be edited.
    The problem is when i ftp to my duo, there is no such directory
    i'm using NFS server that's built into vix 2.3 and have enabled it.
    Where can i find the share configuration file?
    Cheers
    Alan
  • mrmad1966
    • Mar 2012
    • 11
    Alan
    You could download a small program like 'putty' (google it), then use that program to telnet into the duo from there the command vi /etc/exports will allow you to edit the exports file !
    • RuberDuck
      • 1724
      There is no need to go messing with the exports file you can go into the network settings on the image it self and create a network mount between both receivers. for example i have all my receivers network mounted to each other along with a NAS drive so i can essentially access any of 4 different HDD's from any of my receivers.
      • tmontana
        Thanks for your replies.
        Im having a different issue now
        Rubberduck id really appreciate some info from you on this thread
        Have been at it for hours and get get the mount setup
