channels missing, and no sound
  • trance
    • Aug 2009
    • 223
    Hi people,
    I bought a vu duo clone 3 months ago[yes 3 months ago] .
    I finally set it up yesterday,
    Flashed the the secret update kernal
    & flashed the vu with blackhole 1.72
    right then the problems started, First of all I get some channels eg; ssports12 but not 3 and other random channels are missing like good food,[do not clear]
    secondly after rescanning, the sound is missing on some channels eg ssports 4.
    what could it be? Its not my server ,
    Should I just reflash, or is there a solution
    btw i have both tuners wired to my lnb
  • cactikid
    • 12017
    try pressing audio button and select a different stream,or restart cam
    • trance
      • Aug 2009
      • 223
      thanks for your reply, no option to select a different audio stream on those affected, restared cam but still get some channels while others are missing.
      reconnected my dm800se, and everything works fine on that, so at the moment im at a loss
      • potrobber
        • Mar 2010
        • 493
        hi trance
        by any chance are you using mgcamd? as i have the same problem but switch cccam back on and all channels are there
        any one else getting this with mgcamd on duo?
        • trance
          • Aug 2009
          • 223
          hi, potrobber finally got around to setting up my vu clone.
          just swapped cam from mgcamd 138 to cccam 221, and just like you said all the channels clear.
          My server recommends I use mgcamd, so gonna try another image or different mgcamd to have a look and see how it goes,
          potrobber what image do you use, and has mgcamd always caused problems for you on vu's
          cheers
            Well i use both Cccam2.2.1 and MGcamd1.38 on mine and can honestly say have not had a single problem with any channel
            • trance
              • Aug 2009
              • 223
              digicon , what image are you using
                Blackhole (1.7.3 Skin Tribute)
                Have had SSN on for the last few hours using MG1.38 and not a blip
                • potrobber
                  • Mar 2010
                  • 493
                  evening guys i cant get my head around this at all
                  trance i have tried few different mgcamd and im now loading 1.7.3 bh on but had 1.7.2 on before and still could not get it to keep opening all channels
                  digi where are you getting mgcamd from im using ts panal are you taking it direct from somewhere ?
                  digi is settings in mg_cfg ok and thanks for your time m8
                  # EMM messages
                  # 00 don't show any EMMs (default)
                  # 01 show only valid EMMs
                  # 02 show valid and bad EMMs with complete data display
                  M: { 00 }
                  # ECM messages
                  # 00 don't show anything about ecm
                  # 01 normal mode, show pids processed, decoded ecm and cw
                  # 02 verbose mode, show valid and bad ECMs with data
                  C: { 01 }
                  # AU
                  # 00 disable, no emm pids processed
                  # 01 enable, emm pids always processed for soft-au and shared cards
                  # 02 auto, emm started only if channel cant be decoded
                  # 03 process emm pids for network cards update only
                  A: { 00 }
                  # key update (sum 01 or 02 with 04)
                  # 01 update only new keys, default setting
                  # 02 update all keys (used for valid PMK checking)
                  # 04 enable TPS au
                  # + tps SID, which pmt pid contains au pid
                  U: { 02 } 0x12c0
                  # config files folder (softcam, autoroll, ignore/priority)
                  # 00 files in /var/keys
                  # 01 files in /tmp
                  T: { 00 }
                  # network mode, use summ for several clients
                  # 00 no network (default)
                  # 01 newcamd netclient
                  # 02 radegast netclient
                  # 04 camd3 netclient
                  # 08 gbox netclient
                  # 32 cccamd netclient, card list saved as /tmp/cccamd.info
                  # (ECM only, supported server version up to 2.1.1, later not work)
                  G: { 33 }
                  # network retry, use summ for several options
                  # 00 disable
                  # 01 retry every new ecm
                  # 02 try to connect to offline shares every Q: seconds
                  # 04 try to detect and fast reconnect to lost (and not used atm) server
                  # + XX messages number and YY seconds to reconnect
                  # mg will reconnect to server, if no answer to last XX ecm/keepalive or
                  # if no answer for last ecm or keepalive sent for YY seconds
                  # set to 0 to disable
                  N: { 07 } 360 3600
                  # network ecm timeout in seconds
                  K: { 05 }
                  # newcamd dead routes connect retry, sec
                  Q: { 10 }
                  # network shares priority
                  # 00 gbox, newcamd, cccamd, radegast, camd3 (default)
                  # 01 camd3, radegast, cccamd, gbox, newcamd
                  # 02 cccamd, newcamd, camd3, gbox, radegast
                  P: { 02 }
                  # on screen display type
                  # 00 No OSD (default)
                  # 01 neutrino
                  # 02 enigma
                  # 03 relook
                  # + user password for http auth
                  O: { 02 } root password
                  # on screen display Options, summ of:
                  # 01 show emu ecm
                  # 02 show network shares messages
                  # 04 show decoding failed / fta
                  # 08 show emm keys update
                  # + web port to use for osd
                  S: { 03 } 80
                  # Log option, summ of:
                  # 00 off
                  # 01 network udp log
                  # 02 log to console
                  # 04 file, appended ! delete it by yourself, before it eat all your hdd
                  # + IP udp-port log-file-name
                  L: { 02 } 172.16.1.1 28007 /tmp/mgcamd.log
                  # keep ecm cache, seconds
                  # every cache entry takes 28 bytes, so 24h cache will take *only* 240-400kb of memory,
                  # for openbox/elanvision users with remote shares make sense to set it higher than default value,
                  # to not hammer cards while timeshifting or playing crypted recordings.
                  E: { 00 }
                  # cache option, summ of:
                  # 00 Off (default)
                  # 01 Ecm pids cache, store pids used to decode in /tmp/ca_cache.list at exit, load at startup, same syntax as restore.list
                  # 02 Ecm data cache, remember CW for (E time
                  # 04 Emm cache for network cards, do not resend the same emm twice, cache not cleared until restart
                  H: { 00 }
                  # reread files, summ of:
                  # 00 No (default)
                  # 01 reread config file on channel change (including priority and ignore, but not replace/cache)
                  # 02 reread SoftCam.Key on channel change
                  # 04 reread SoftCam.Key if file changed
                  R: { 00 }
                  # debug, summ of
                  # 00 off (default)
                  # 01 debug ecm
                  # 02 debug emm
                  # 04 debug network ecm
                  # 08 debug network emm
                  # 16 debug network login
                  # 32 show mem/cpu stats every 1 min
                  # 64 add timestamp to log messages
                  D: { 31 }
                  # box type
                  # 00 autodetect, change only if you think wrong type detected.
                  # 01 dbox2
                  # 02 dreambox
                  # 03 triple-dragon
                  # 04 relook
                  # 05 openbox
                  # 06 dreambox/mips
                  # 08 stapi/kathrein
                  # 09 stapi/ipbox
                  # 11 stapi/openbox
                  B: { 06 }
                  # map all 180x nagra caids to 1801
                  # default is 01
                  F: { 00 }
                  • trance
                    • Aug 2009
                    • 223
                    potrobber, i just found some info another site which said this;
                    Just to say I got it sorted and for anyone with this problem you need to go into mg_cfg. in usr/keys and as alpa says, change box type to B { 0 6 }. Hope this helps!
                    Ive just tried this and all seems to be fine now with everything clearing on mgcamd,
                    having said that ive just seen your mg cfg file and your file already has the right setting so thats even more strange
                    • trance
                      • Aug 2009
                      • 223
                      OK, just an update, I just flashed bh 1.73, but still had the same old problem with mgcamd 138,
                      so I performed the trick above and now its working fine
                      • tan3
                        • Apr 2012
                        this thread was a life saver...thought i was going crazy after i put the new image in......
                        ps hi all....new to this duo scene..... cracking box....
                        thanks again
                          DO NOT and i repeat DO NOT get your softcams from TSpanel on blackhole image this is what is causing the problem more or less, I have the so called official ones that are just for the Blackhole image.
                          Not too sure if i can up them here but probably not due to rules
                          • RuberDuck
                            • 1724
                            agreed, i personally find the quality control of included plugins rather lacking for TSpanel.
                            • potrobber
                              • Mar 2010
                              • 493
                              thanks digi
                              tspanal emu manager install of mgcamd was causing all the trouble
                              i take its just with blackhole images this is happening on?
                              i for one will be giving tspanal emu manager cams a wide berth from now on
                              thanks all for help
