hard drive for vu
  • kudisa
    • Apr 2012
    • 10
    hard drive for vu
    after deciding to buy a vu duo( not ordered yet) i was looking for some hard drive to fit in and found one laying around a external freecom 400gb. i open the casing to see the specs:
    400GB/7200rpm/8M/PATA.
    i assuming that this one is not good right?
  • Rodbouy
    • Jul 2010
    • 1320
    Any 3.5" sata will fit it mate.
    • kudisa
      • Apr 2012
      • 10
      but the one i have is 3.5" pata
      • Rodbouy
        • Jul 2010
        • 1320
        no you need a sata pata doesnt wor. Not unless there is a converter.
        • kudisa
          • Apr 2012
          • 10
          ok i was afraid it wouldn't work
          • dell_xps
            • 2558
            SATA you need m8, or get a converter from ide to sata on the bay, or just use it as an external drive with your VU, easy.
            • kudisa
              • Apr 2012
              • 10
              due to short on funds, does the converter works well with the box or i need a sata hard drive. i'm not a fan of external and it will look ugly and missus would kill me.
              • dell_xps
                • 2558
                Sure someone on here posted they were using one m8, do a search !
                • kudisa
                  • Apr 2012
                  • 10
                  Took the plunge and order one ysterday.
                  Regarding epg and picons is the any big diference using usb stick or hard drive? I have harddrive to fit do i realy need to use the usb stick or the hd will do the job. There is nothing left on pig bank
                  • dell_xps
                    • 2558
                    I use a hard drive for picons/epg/vfd etc etc, a lot of peeps use a usb stick, probably quicker using a usb stick, but if yer not bothered, stick them on the hard drive if funds are tight.
