tuner issues
  • Bumsrus
    • Apr 2012
    • 65
    tuner issues
    Does anyone know the correct tuner settings for a motorised dish,
    many thanks
  • dell_xps
    • 2558
    Sorry m8 just got a static dish, few guys on here should be able to help you though.
      Menu - Setup - Service Searching - Tuner Configuration Pick which tuner you want to set to motorised either A or B and then change Configuration mode to Simple - Mode - Positioner and enter your Longitude and latitude setting.
      Remember to change your Longitude from East to West
      • Bumsrus
        • Apr 2012
        • 65
        so far i have tried tuner a;
        positioner
        input my settings ie, 53.000 north, 002.000 west
        tuner B: set to equal to tuner A-
        also tried vice versa but scan never goes past 0% and gets stuck on 8.0w alantic bird 2
        i have tried a simple search on single
        28.2 eurobird
        diseqc - no
        and this picks up all channels expected
        any advice on where im going wrong?
        • potrobber
          • Mar 2010
          • 493
          any word on what happened your duo clone ?
          • Bumsrus
            • Apr 2012
            • 65
            not really any update potrobber, still left with a shiny black box with a red dot, kinda given up with the clone. very happy with original, but would be even happier if i could get the motorised dish working
              personally i cannot understand people scanning for channels on an enigma 2 receiver when all available channels are available from the very nice people called Catseye,Vhannibal,Sgtflipflop etc...
              Save a lot of hassle and if your install is setup correctly will pick all the available channels that are within your Dish size & area.
              • RuberDuck
                • 1724
                Because more often than not those very same bouquets are out of date at the time of their release especially ones like catseye who only tend to release once a month.
                I personally use a combination of SGTFlipFlop and Vhannibal but do occasionally do a scan as well on certain satellites, such as 28.2 east as this only takes around 4 minutes to do a full blindscan with the uno / ultimo on this satellite location.
                • Bumsrus
                  • Apr 2012
                  • 65
                  Would the bouquets pick up all channels on a server? or only just 28.2. Sorry about the noob question
                  • RuberDuck
                    • 1724
                    the bouquets are a channel list and as such have nothing to do with your server.
                    now depending on who's bouquets you use they can cover a single satellite location or a many.
                      Transponders change rarely on most satellites and doing a blindscan on 28.2? east is really unnecessary for one it doubles up on Tp's and channels.
                      Blindscan feature on receivers is more used for when trying to find an odd occasional feed on a satellite that may be there one day and then gone the next.
                      • RuberDuck
                        • 1724
                        like any other scan method you can choose the clear before scan option in blindscan. as for doubling up on TP data that is just plain wrong as the found TP's are not written to the satellites.xml at all, they are discarded however in ViX we have added a feature where you can save this data to a separate file so that you can check it if you want to.
                        • mtv1
                          The Stig PT
                          • 4413
                          however in ViX we have added a feature we are not worthy
                          had a problem with a vu+ duo turned out to be the dish slightly out sd and hd thanks for your help
                            That was my point why scan a whole satellite when no TP data is stored at all, Because its already on the sat.xml file which can only be edited manually and not by the receiver.
                            • Bumsrus
                              • Apr 2012
                              • 65
                              Right, installed Catseye bouquets, i can see all the different folders ie sky uk movies, sky uk sports which all work correctly, however when i choose a different satalite ie hotbird 6 and choose sky italia news there are no channels available not even fta, and this is the same with all other satalites. What am i doing wrong ?
