Mgcamd 1.38 for Blackhole
  • dragonevo
    • 24
    Anyone knows where to find mgcamd 1.38 file for blackhole image?
  • asad5150
    • Oct 2008
    • 185
    download it from the tspanel on the blackhole fimrware
    • potrobber
      • Mar 2010
      • 493
      do not download it from tspanel emu manager as it does not run correctly on blackhole images some channels wont open after a hour or so
      download it from tspanel addons section making sure to select it for blackhole, linux support addons is ok to get it from
      the mg_cfg config file needs some settings changed also edit it and change
      g = ( 33 )
      k = ( 07 )
      p = ( 02 )
      b = ( 06 )
      change the above settings and exit and save enter line and save then restart cam in blue panel
      • dragonevo
        • 24
        Im running mgcamd 1.35 with the tuned mg_cfg now...
        Seems running good, but will it work even better if i upgrade to mgcamd 1.38??
        • potrobber
          • Mar 2010
          • 493
          i have not seen any difference in the 2 if your running good on 1.35 and not getting any faults how much better can it get 1.38 will run just as good
          what part would you like to get better?
          when mg_cfg is set up right and its running fine i can not fault 1.35 or 1.38 or see any difference in the 2
          im sure there must be some difference but for normal tv viewing both cams are great with fast start up and response times
