VU+ Duo CCcam 213
  • mrblue
    • 568
    VU+ Duo CCcam 213
    Working great but when i reboot box i have to go into tspanel to restart cccam, any reason why this is....?
  • asad5150
    • Oct 2008
    • 185
    i think u need to put ccam as default softcam
    • mrblue
      • 568
      I think so too. I presumed i did it in the blue panel but it wont let me, common interface is down as default cam.
      Sometimes when switching between channels, a message appears switching cccam to common interface and vice versa
      • potrobber
        • Mar 2010
        • 493
        did you install CCcam from tspanel emu manager ?
        or download it from the addons section in tspanel?
        • mrblue
          • 568
          I just press menu, then select tspanel, then select softcams then press blue for install.
          Is that correct or is there a different method I should be using...?
          • potrobber
            • Mar 2010
            • 493
            what image you on and what version tspanel? and why do you want old version of CCcam
            i would use 2.2.1 if needed CCCam but find mgcamd a little better
            go to tspanel uninstaller and remove all cams and configs
            then go to tspanel addons / then linux support addons and download from where it says blackhole other
            then just start the cam by hitting blue button and ok if your using blackhole
            • mrblue
              • 568
              Im using a black hole phoenix edition image, this
              simSSde-133dv3PHOENIXdm13052011
              Have updated to latest 5.4 tspanel. Will try your method now.
              Guy that does my line told me to use cccam 213 or 214
              • cactikid
                • 12017
                did i hear the 214 had a warning not to use as its a tracker or worse?
                • mrblue
                  • 568
                  No idea but box is going well now, cccam doesnt need to be restarted when I reboot box.
                  These channels are poor quality, very glitchy, no problems with server, using 04.05.12 sgtflipflop channel list.
                  Another problem is some channels are being display as 4.3 so there are black vertical borders down each side of tv, how do I correct this...
                  Faulty hd channels, still have to check sd
                  SYFY HD
                  FX HD
                  E4 HD
                  BIO HD
                  GOOD FOOD HD
                  EUROSPORT HD
                  ESPN HD
                  DISCOVERY HD
                  • potrobber
                    • Mar 2010
                    • 493
                    hi cactikid
                    there is word on the net that 2.30 has some sort of backdoor tracker or something
                    i have never heard any storys about 2.14 i use mgcamd now so do not think about cccam any more
                    maybe some one that knows the full story about what the scam or fault with the 2.30 cccam is anyone know?
                    • cactikid
                      • 12017
                      as i dont use that cam i was not sure,if you say it was 2.30 it must have been that one.mg yes better cheers.
                      • mrblue
                        • 568
                        Have checked kos, frequency for espn hd is 12324, v 29500 3/4. Scan done 8 new services found
                        Discovery HD
                        ESPN HD
                        ESPN HD
                        3843
                        SYFY HD
                        SBO HD1
                        4034
                        SKY BOX OFFICE
                        No good, if you go to ESPN HD and bring up manual sat scan, these are settings that were already being used...
                        • gramps
                          • 20
                          sorry to add this ... so excuse my ignorance
                          is a dm800 image.... this is a vu+ duo chat
                          so i would suggest mrblue looks in the dm800 area for answers or gets a rev m tuner for his box
                          • cactikid
                            • 12017
                            easily gets confused at to what box the problem is with.
                            • potrobber
                              • Mar 2010
                              • 493
                              the duo box he got had 1.72 blackhole and all set up for mgcamd only needed line and channel list to finish
                              you seem to be going the wrong way with this blue m8
                              where did you find that image? or is this a dm 800 your playing with and not the duo?
