Mgcamd needs restarting all the time
  • andy211081
    • 575
    I have installed new vix image, i watch a channel and its fine ten mins later i change channel and its black so restart cam and sometimes work if not i have to restart box just to get it to work!
    Anyone any ideas?
    Andy
    Ladies and Gentlemen, this is your captain speaking. I have the only gun on board. Welcome to Con Air.
  • danivtec
    • Mar 2012
    • 75
    Which Mgcamd version are you using?
    I have 1.35 installed on ViX 2.4 but have been using CCCam so havent tried it.
    • andy211081
      • 575
      1.35 will try a diff version
      • potrobber
        • Mar 2010
        • 493
        did you install mgcamd thru tspanel emu manager by any chance ? as this causes the problems you have
        also what settings you got for ( g ) (k) ( p) and ( b) in mg_cfg ?
        • andy211081
          • 575
          I tried adding thru tspanel but it wouldnt work so i found one for vix on here so installed that one.
          Some channels clear ok, some beed the box to restart, and recording is not working! I know the image is a work in progress so will jusy have a play around!
          • andy211081
            • 575
            I will have a look at cfg tomorrow
            • danivtec
              • Mar 2012
              • 75
              I can uplaod my mg_cfg if needed which appears to be working.
              • andy211081
                • 575
                I altered the mfg to replace 0 with 6 at line 131!
                Channels clear but it takes about 10 seconds! Does anyone have any ideas?
                • potrobber
                  • Mar 2010
                  • 493
                  m8 change g to 33 ,, b to 06 ,,k to 07 then see how it goes
                  also are you using c or n lines?
                  • andy211081
                    • 575
                    i am using n line ..i have changed cam from 1.35 to 1.38 to see if that will help also
                    thanks for advice will do that also
