Got a Duo clone from Aspleys about 6 weeks ago which has been ok with a fixed dish on 28E and a dual feed 80cm on the other tuner, running BH 1.7.3.
( did have early problem with sticking fan similar to another post - had to flick it to start it but replaced it with one from a hdd cooler powered by sata cable)
Anyway this week I've motorised my 80 cm dish using a supreme dark motor. Alignment seems fine getting decent signals on all the sats I would expect to receive from 45E to 30W. Usals set up I'm sure is fine.
Sometimes when changing satellites I totally lose signal although the dish appears to be moving ok. Manually adjusting dish via menu doesnt help so I reboot and all is fine until the next time.
At other times I have been zapping through a particular sat and go to a channel but get no picture or sound despite channel being fta and good signal. When this happens all channels go the same way even on tuner 1 via the fixed dish on 28E.
Strange one here when this happened last night I tried to rescan 10818 v on 28E and got channels from 11223 v !!
Again a reboot fixes this until the next time (only a full reboot works,restarting enigma doesnt work).
Reluctant to reflash unless the image is the problem as I've spent a lot of time setting it up as i want it but its been fine until I motorised the second dish.
Anyone got any ideas before I contact the dealer?
