best replacment fans ?
  • the man
    • 1660
    hows this look Mini Kaze 50 mm: CPU K?hler, L?fter, L?ftersteuerung, PC Netzteile von Scythe
    any good 2 pin ones out there?
  • IAmATeaf
    • 591
    That fan spins faster and is also noisier and it has sleeve bearings so may turn even noisier after a bit of dust gets to it.
    No idea if the fractal mentioned in the other thread has ball bearings but some sites suggest that it does, spins at a lower speed and is much quieter.
    • the man
      • 1660
      i need one wite 2 pin only tho
      • IAmATeaf
        • 591
        Didn't somebody in the other thread respond about this? The 3 pin connector can easily be removed from the new fan and replaced with the 2 pin from the current fan.
        Here's a vid on how to remove the connector [ame=http://www.youtube.com/watch?v=iUUxt6GBV6A]How To: Remove/Install 3-Pin Fan Connectors - YouTube[/ame]
        • the man
          • 1660
          thanks mate , now i understand , new fan it is
          • IAmATeaf
            • 591
            No probs, you don't need that 3 pronged tool that the guy uses in the vid, a very small screwdriver or even the end of a paper clip would do, the 3 pronged tool just means that you can take all 3 cables out at the same time, using a small screwdriver or paper clip would mean you'd need to take 1 cable out at a time.
            Before you pull the connector off make sure you make a note of how the cables were on the new and the old fan. Also when you pull the cable out you'll notice on the cable that there's a small tab, you might need to slightly lift that back up to ensure that when you put the cables back into the 2 pin connector the cables lock in place securely.
            Difficult to explain but when you start you'll hopefully see what I'm talking about.
            • the man
              • 1660
              OK fitted the silent fan
              Fractal Design Cm 50mm Silent Cooling PC
              now problem , it works fine but i have to bump start it , it needs to start it by hand , it trys to start but look like theres not a nuff power , I used the red and black wires only in the 2 pin connector, any advice guys?
              • IAmATeaf
                • 591
                How old is your box and is it a clone?
                If the box is one of the first then there was a mod for it change a resistor on the motherboard to resolve this issue, you can find it over on the Ferrari forums.
                • the man
                  • 1660
                  nope new clone v2 mate ,
                  herd turning the fan in the box around work s, but not sure if it helps ?
                  • IAmATeaf
                    • 591
                    What if you loosen the screws just in case it's somehow catching on the metal grill?
                    • IAmATeaf
                      • 591
                      If you look directly under the fan header on the motherboard, there are 4 small components with the 3rd from the left missing. The 2nd from the left, can you check what numbers it has, some of the early batches had a 220 Ohm resistor soldered there, later batches have a 100 Ohm which effectively is the fix.
                      The other thing to try is unscrew the fan completely and then check if it starts up, if it does then when mounted something is obstructing it.
                      • portbhoy
                        • 717
                        Mine worked 1st time but there is very little clearance between the pcb and the fan just make sure it isn't fouling,also I used the screws that came with the fan and the fan label goes towards the outside of the box.
                        • the man
                          • 1660
                          thanks mate , tryed it out of the box as-well no good , I'm trying to get a refund for the box now as iv had to many problems TBH , will look at a VI uno original
