pic of the on off buttom set up? or info
  • the man
    • 1660
    iv taken it apart as there Wire sparks coming from it on the inside (clone) after the psu blew up , ffs scary but i have a extra psu to try
    all i need to confirm is witch way the wires go on to the power switch
    is the rite
    red one on top on psu goes on the upper left connector
    red one on bottom on psu goes on the upper left conectore
    black one on top on psu goes on the upper right connector
    black one on bottom on psu goes on the upper right connector
    pleases look , upload a pic of you setup
  • potrobber
    • Mar 2010
    • 493
    with the lid of the box and looking at it from front the block of 4 wires the 2 blacks are on left and 2 reds on right this is on connector pushing into psu
    the switch looking at it from front of box has 2 reds on left and blacks on right
    • IAmATeaf
      • 591
      Providing that both blacks wires and both reds are on the same side I don't think it matters. So keep both blacks wires on the left and both red wires on the right would also work. When looking at the connector on the PSU itself, again the same thing applies, keep both the same colour on either on the left or the right.
      • the man
        • 1660
        thanks guys
        on the psu the clip is on the right ???
        • IAmATeaf
          • 591
          Originally posted by the man
          thanks guys
          That's sound like how potrobber has his, the important thing to keep the same colour wire vertically, so the reds are above/below each other and the same for the blacks.
          If you look on aliexpress, search for vu duo free shipping then find a seller called Define, they have pics of the internals and you can just about make out where the wires go.
          • potrobber
            • Mar 2010
            • 493
            thanks guys
            thats how they leave the factory and will work the other way also as stated by i.a.a.t
            and your clip is correct also
            • the man
              • 1660
              thanks have set up like bottom pic on link VU+ Duo Twin Tuner Linux HDTV Receiver PVR, Digital Satellite TV Receiver-in Satellite TV Receiver from Consumer Electronics on Aliexpress.com
              not working so sending it back
              • DOUGALMCD
                • May 2011
                • 3229
                Have you tested switch to see if it still works?
                • the man
                  • 1660
                  how to do that pal? do they brake offten?
                  i think the switchs ~~~~ed tbh ,
                  • DOUGALMCD
                    • May 2011
                    • 3229
                    For information only : Do you have a multimeter? line test will beep when switch is on. It won't when off. It won't beep at all in both positions if knackered. [ame=http://www.youtube.com/watch?v=tDQ0X1LRhpg]Dryer Switch Testing - YouTube[/ame]
                    Same principal applies to testing your switch. Black pin to Black pin test. Red pin to Red pin test. HTH
                    • the man
                      • 1660
                      nope , sendng it back , so hope to get a refund thanks pal
                      • IAmATeaf
                        • 591
                        Silly question, possibly but have you checked the fuse in the plug?
                        • the man
                          • 1660
                          yep but had sparks from the on off switch , im calling it a day pal
                          • cactikid
                            • 12017
                            wise choice i think you dont want your home burnt down,now while we are on that subject,have you tested your smoke alarms??too late you may not be around then.
                            • the man
                              • 1660
                              will test fire alarms 2morow !
