Need firmware or plugin to set up bouquets???
  • clem58
    • Aug 2009
    • 819
    New to vu+ duo, i need to set up a bouquet list or 2. What do i need to do to get started and how do i approach it. An idiots guide would be helpful.
    Also i got my vu last Tuesday, when i set up the 1channel i was really chuffed, now the tv section of it won't work. How do i resolve it?
    Thanks in advance for replies.
  • clem58
    • Aug 2009
    • 819
    I have at long last created a bouquet list, but, if needs be how do i delete a channel from it? I have a few blank ones among the freeview list. And is it possible to pick up dave? not the person the channel.
    • cactikid
      • 12017
      Search Results for - KingOfSat
      never deleted anything yet,not too sure if you press menu while on that channel may give you other options.
      ok while you are on the list of channels go to one you want to select then press menu,that gives you options to choose from.
      • clem58
        • Aug 2009
        • 819
        (Dave) do i check this out on the sat options, wondered why i had a list of four sat signals that look similar. I can only do these things in afternoon, because sat box in l/room. come emerdale, i be sent to the corner.
        • cactikid
          • 12017
          as you should only have one sat 28.2 on a fixed dish they were the results of a name search on kingofsat,they will give you the settings if needed to do a manual scan.what other sats are listed?
          • clem58
            • Aug 2009
            • 819
            Can't say , the commandering chief came in at 6 took over tv. can't look until 2moro. Recording is the most important issue i have at min. When i set record or press record i get either blank screen, the epg goes grey or i seem to record a whole list of channels of that name.Thats my nxt challenge, i think i might know what ur talkin about about manually tuning a channel. Ta for ur reply.
            • clem58
              • Aug 2009
              • 819
              Can't say , the commandering chief came in at 6 took over tv. can't look until 2moro. Recording is the most important issue i have at min. When i set record or press record i get either blank screen, the epg goes grey or i seem to record a whole list of channels of that name. How many channels can this thing record simultaneously while watching another?Thats my nxt challenge, i think i might know what ur talkin about about manually tuning a channel. Ta for ur reply.
              Picture quality is quite good on sd channels compared to freesat humax box.
              • clem58
                • Aug 2009
                • 819
                None only sats are sky, 2 or 3 of them. never looked at manual tune for dave to-day, i was pre occouped with trying to use recording n wot not, spent an hour goin thru that. Anyway i have an issue when it comes to recording. I can't record similtaineous programs while watching another. Can it be sorted. Thanks in advance folks. VU+DUO by the way.
