probelms after loading multi-sat bouquets
  • the goat
    • Mar 2010
    • 122
    hi all
    just got a vu+ duo, was working ok with just bouquet for 28E
    loaded cateyes multi sat bouquet (using dreamboxedit) now vu+ duo restarts everytime i select a channel to watch
    fault log says
    Jul 16 14:55:08 vuduo daemon.debug CCcam: ================================================== ====================
    Jul 16 14:55:08 vuduo daemon.debug CCcam: online using nodeId f92ade1a359826e
    Jul 16 14:55:08 vuduo daemon.debug CCcam: readKeyfile: cannot open /var/keys/SoftCam.Key or not found
    Jul 16 14:55:08 vuduo daemon.debug CCcam: readKeyfile: cannot open /var/keys/AutoRoll.Key or not found
    Jul 16 14:55:08 vuduo daemon.debug CCcam: static cw not found or bad
    Jul 16 14:55:12 vuduo daemon.debug CCcam: server started on port 12000
    Jul 16 14:55:39 vuduo auth.info login[453]: root login on 'pts/0'
    Jul 16 14:55:42 vuduo user.info kernel: warning: `vsftpd' uses 32-bit capabilities (legacy support in use)
    i tried load just 28E bouquet but still not working
    is there something easy i can do, or do i have to reflash vix and start again
  • DOUGALMCD
    • May 2011
    • 3229
    Sounds like you better start from scratch good luck.
