Duo clone
  • Shamonee
    • Dec 2011
    • 119
    Duo clone
    Hi work colleague has just got a clone duo. Added nline through ftp but still not opening channels.
    It's running Blackhole image 1.7.0, Jan 8th 2012.
    I assume no cccam is installed, is this through tspanel?
    if so where do I get it from? Does the version depend on the image being used?
    Do I ftp it to temp folder?
    I only have an openbox, had a dm500s back in the day
  • benny/9
    • 1964
    if you press the blue button, you will see if any cams are installed
    also lines go into the cccam config file in the etc folder on the box
    Please Read Carefully!
      If its an N: line then you would be better off running it through mgcamd, with TSpanel installed go to one of the feeds on there and go to select a cam download remember to look for Blackhole cams.
      Once installed and rebooted N: line goes into usr/keys folder inside the newcamd.list file, the best editor for opening newcamd.list is notepad++ which is a free download.
      • Shamonee
        • Dec 2011
        • 119
        Sorted just downloaded tspanel and uploaded. Seems to be working fine.
