wonky led display on duo
  • spudorange
    • 242
    Received a couple of vu duo clones today.
    Both have a wonky display on front panel, whichever image is used.
    I have checked the ribbon cables but nothing helps.
    Anyone have a solution please
  • Rodbouy
    • Jul 2010
    • 1320
    when you say wonky, what is it they are doing?
      its only got 3 legs
      • spudorange
        • 242
        start of text display is at bottom left of display
        the end of the text is at the right hand top
        as in, rising upward from left to right
        • DOUGALMCD
          • May 2011
          • 3229
          Do the boxes work otherwise?
          • cactikid
            • 12017
            has the box got water stains on board when you checked the ribbons?
              you will have to take the lid off and then the front plastic panel which will expose the display gently twist it until straight and replace front and lid.
              Be very careful when you twist it or you will need the soldering iron.
              • kaisar1
                • Aug 2009
                • 462
                yh mine had similar problem. i just adjusted it back in place. there should be some holes which you should align the bottom of the display with.
                • Rodbouy
                  • Jul 2010
                  • 1320
                  I also had one like that. It all comes apart easily. just take your time. Then put it all back together. Easy fix
                  Remove screws, then pull out ribbon. Then remove the screen and front dial. Fix it all back in place and lined up correctly.
                  You will have to give the dial a good push so its fully back in place other wise when you put it all back on it won't move.
                  • spudorange
                    • 242
                    thanks guys
                    will give it a try
                    strange it's on both boxes eh?
                    • wurz
                      • Apr 2010
                      • 123
                      Originally posted by spudorange
                      thanks guys
                      will give it a try
                      Not strange at all. I would say 80% of all clones that I have seen have this issue. On others the display wont come back on after being adjusted so my advice is to be extremely careful to anyone attempting to fix this.
