VU Duo Clone Help
  • murphyb007
    • Aug 2012
    • 88
    VU Duo Clone Help
    Hi All, I purchased two Vu Duo Clones from China last week, One I have bricked already but I am on to that, the other I tried to set up for my dad... I guessed it was plug in Tune and wham, all would be OK! Clearly not...
    I set Tunner A to Astra 28.2e, Port a and port b and the same with Tunner B. It showed about 1000 stations, I.e Channel 4 came up in the list 5 times! but when I went in to view anyone it would not let me view. How do I pick up the local freesat stations in order i.e BBC 1, 2, UTV (ITV) 4 Channel 5 etc, to allow me to watch them? Any help would be greatly appreciated.
    Thanks.....
  • DOUGALMCD
    • May 2011
    • 3229
    Both A & B Tuners set to simple single 28.2e send diseqc to no
    You seem to have scanned and received channels so once rebooted check last scanned channels not favourites. You should be able to select channel to view now. You will still have to load channel lists later as this makes viewing easier.
      Thanks.....
      Simple load a pre-configured channel list in
      • murphyb007
        • Aug 2012
        • 88
        A step further
        Thanks Guys, I have learnt were I went wrong with the list of channels, I now have a list of many, How do I go about to load a pre-configured channel list? thanks in advance.
        Brian
        • potrobber
          • Mar 2010
          • 493
          download dreambox edit and use that to install channel lists
            You can either do what Potrobber suggested or depending on what image you have loaded you can get a Channel list direct from the Feeds and install one that way.
            TSpanel is a good plugin for finding the latest channel lists as well as other plugins etc...
            • murphyb007
              • Aug 2012
              • 88
              Thanks, Were do I get the full Sky Channel lists from? Just discovered Vu Control Centre, LOL. and a button called update channel list, which when clicked takes me to my folders? Is this how I get them once downloaded? Could you maybe give me a link to the correct Channel list? Also, do I need to use Filezilla to make use of Vu Control Centre, So much to take in
                If you just want a Sly 28.2? east only list then have a look for MrMister's or even SGTflipflop they are good ones.
                • murphyb007
                  • Aug 2012
                  • 88
                  Excellent.. I have just installed my first channel list! Thanks all for your help... Although there are now numbers beside the channels, when I press say, 101 (BBC1) or even 1, it does not jump to this station? Is it supposed to?
                    It should do yes but most people just use the pre-configured favourites bouquet
                    • murphyb007
                      • Aug 2012
                      • 88
                      Thanks for that, have mastered the bouquet downloads now,slowly but surely, the next thing I need to do now is learn the time shift Craic, from what I understand I need a hard drive installed or is there settings I need? Thanks In advance
                        no you just need a hard drive installed no magical settings to get it to work, once installed you can record direct from the EPG just like a sly box
                        • portbhoy
                          • 717
                          Use a laptop hard drive mate a 3.5 is not recommended.
                          • murphyb007
                            • Aug 2012
                            • 88
                            Cool, that's the recording, what about pause and rewind etc?
                            • kaisar1
                              • Aug 2009
                              • 462
                              why is a 3.5' hard drive not recommended???????
                              i got a one installed, and also usb laptop fan installed underneath the receiver
                              thanks.
