stream vu duo to pc xbmc. possible????????
  • kaisar1
    • Aug 2009
    • 462
    hi all, just wondering if its possible to stream vu duo to xbmc pc software.
    i know i can stream channels via openwebif but the thing is everytime i want to watch a channel i have to download stream.m3u. on my dm800 i can watch channel via webplayer.
    anyone know how to set this up?
    thanks.
  • chrismoore02
    • Jul 2011
    • 523
    This would be a good feature if can be setup
    • pspmixer
      • Jun 2009
      • 750
      yes i second that would be a great feature to have
        Blachole Image Tuner server is compatible with XBMC and other devices, A quote from the site from one of the users.
        just for report:
        tuner server works fine with apple atv2 with xbmc with sd and hd , but not all hd channels eg the raihd sat one play just the sound
        • nimo
          • Jun 2009
          • 45
          You can setup your Vu+duo into XBMC (tested on windows and iphone)
          Just use tuxbox as network input then enter your box ip, username and password, then you will access your channel directly on XBMC
          Also there are XBMC plugins for that, like Live TV which has also the EPG
          Let me know if you need more info
          • kaisar1
            • Aug 2009
            • 462
            thanks, could you help, is there any instructions to setup etc?
            • nimo
              • Jun 2009
              • 45
              On the Vu+Duo:
              Install either the WebInterface or the OpenWebIf
              Enable the one you want
              Also you need to install the tuxbox extention for this to work
              On the PC/Iphone:
              Install XBMC
              Go to Video Files, Add Videos..., Browse, Add network Location..
              In the protocol chose Tuxbox Client
              Server address, well, your Vu+duo ip
              port, well the port you have for WebInterface or OpenWebIf
              username: root
              password: <putyourpasswordhere>
              Then click ok, it will load your channel list/bouquet, then select it and chose a name of this input
              Hope this helps!
              Regards
              Alex
              • kaisar1
                • Aug 2009
                • 462
                where can i download 'tuxbox extension' from?
                using vix 2.4 build 155
                • nimo
                  • Jun 2009
                  • 45
                  You can download the tuxbox entention from the plugin section of Vix 2.4
                  • kaisar1
                    • Aug 2009
                    • 462
                    menu > plugins > (green) download plugins.... sorry feeds are down for maintenance.
                    is that what you mean by 'vix plugin section'?
                    • matlock67
                      • Jul 2012
                      will this work with a rasberry pi, running openelec, also ive installed the very latest version of vix
                      • gregsneddon
                        • Sep 2012
                        if you search for the vu+ pvr plugin for xbmc really simple to set up - bang in the IP of your vu box - everything from EPG data to recordings on the box show up. You will need the PVR Branch of XBMC. Google is your friend here...
                        • redondo5
                          • 277
                          On the Vu+Duo:
                          On the PC/Iphone:
                          Install XBMC
                          username: root
                          Hope this helps!
                          Regards
                          Alex
                          thanks for this. got this to work on ipad 3.
                          but can't get HD channels to appear, just get audio. i'm assuming it has something to do with the wifi?
                          if this was setup on xbmc on an apple tv 2 for example it would be capable of viewing hd channels?
                          • iky
                            • Dec 2012
                            is it possible to this or something similar to this with openbox s9
                            • Peterjones
                              • Dec 2012
                              • 34
                              My R Pi is being a real pain. I can't get the wifi dongle to work on openlec. I have tried two dongles now and none will work.
                              I know its off topic a little, however have you got your Pi working off a dongle? If so what am I doing wrong as I have looked everywhere for a solution and dont seen to be able to find one.
