Bouquets
  • RM6
    • May 2012
    • 19
    Bouquets
    I've recently updated to VIX 3 and downloaded the latest Sgt Flipflop, having previously used the Mr Mister bouquet
    I put all of the radio channels in the Flipflop bouquet to give me the usual sly setup but the only problem is that when I scroll through the channels themselves and hit a radio channel, it takes me to a different channel in the bouquet, usually around the mid 100s.
    This also happened with the Mr Mister one when I reloaded it, so is there something I can do, or is this a quirk of the new image?
  • cactikid
    • 12017
    are you using the latest file from the plugins i presume?that file should contain tv and radio channels stored to box,are you using the buttons on remote to change from tv to radio.
    • RuberDuck
      • 1724
      its a fault introduced by pli after a recent merge with their git but once again they dont consider it to be either a bug or their problem. andy has fixed it now and it will be in the next update.
      • RM6
        • May 2012
        • 19
        It's the latest bouquet from Sgt Flipflop and the radio channels are the ones that were used in previous bouquets to space the channels out.
        The radio channel I use is the one that carries the menu sound from the sly setup, which has been used on all of the bouquets from the past.
        What other plug ins would I need?
        • RuberDuck
          • 1724
          as i said its a fault introduced into the ViX image by pli. pli consider it a feature and not a bug so there not going to fix it. andy has fixed this him self for the new update which he's uploading to the server now.
          • RuberDuck
            • 1724
            read this thread for clarification.
            Channel hopping bug in OpenPLi 3 - [EN] Enduser support - Forums
            • RM6
              • May 2012
              • 19
              Ok, thanks mate, the reply was aimed at the reply above yours but I thought that would be the case.
              I get my downloads from openvix.co.uk so will I have to go elsewhere now?
              • RuberDuck
                • 1724
                no. the image is currently being uploaded to the openvix servers. it may take a while though.
