epg problems
  • lewis65
    • Nov 2011
    • 9
    epg problems
    hi guys, i am having problems downloading a 7 day tv guide.It only wants to download the same day and not the week.I have a duo,i go to set up and select cross epg.Then i select open tv providers and select 28.2 tick it and then press download,it reads the channels but only gives me the one day tv.what am i doing wrong cheers
  • smirnoff_rules
    • 8603
    are u saving to hd or usb ?
    1. Make sure you have a USB stick or HDD attached for EPG data storage.
    2. Press Menu > Setup > System > EPG > Settings. Using left & right buttons either side of OK set the EPG location to /media/hdd or /media/usb. Other settings in this screen can remain as default for the purpose of this guide.
    3. Press green OK.
    4. Now select Crossepg and press OK.
    5. Select configure and press OK.
    6. Change scheduled download to once a day as for most users this is enough.
    7. Set scheduled download time.
    8. Press Red button for BACK.
    9. Select Update rytec providers and press ok.
    10. Select Update XEPGDB providers and press ok.
    12. Select the EPG source that you want to use for EPG data. Do not select more than what you actually use and need as selecting too many will cause memory issues. For the purpose of this guide we will select Open TV Providers > highlight open TV (astra 28.2), press OK to enable this provider and GREEN tick will appear.
    13. Press RED for BACK and keep pressing exit to exit all screen.
    14. Press Blue button > Select Crossepg and press OK. Crossepg will now download EPG data. Be patient and let it finish then the EPG that you selected will be populated.
    • lewis65
      • Nov 2011
      • 9
      hi thanks for getting back so quick.As you can tell i am new to this.I use to be able to view the 7 day tv,but for some reason its gone.not sure what you mean about hdd/usb,the only thing i have fitted is a hard drive to record on.sorry for sounding thick
      • dell_xps
        • 2558
        Make sure you have it set to store epg to HDD not internal flash m8.
        • DMBoot
          • Nov 2011
          • 114
          My DM800 was doing this earlier this week.
          After trying to download a few times with no success, I restarted the box and tried again. EPG then appeared.
          May or may not help you.
