vu duo not switching on
  • asad5150
    • Oct 2008
    • 185
    i havr a clone vu duo for 6months and today it stopped working. i changed fuse but stil doesnt work. it smelt like something has burnt inside the box. i think the power supply has gone can someone tell me what the problem could be. thanks
  • ekkostar
    • 44
    Sounds like the PSU, known problem on both early and newer batches
    • portbhoy
      • 717
      Order a new PSU from Mixeshop around ?20 delivered.
      • IAmATeaf
        • 591
        Be a man and open it up and check out the PSU Look for either burn marks or components that have exploded, if unsure post some pics here.
        • asad5150
          • Oct 2008
          • 185
          can the current psu be fixed?
          • septicsmurf
            • Feb 2012
            • 401
            Depends on what's gone wrong with it and what your soldering skills are like.
            • asad5150
              • Oct 2008
              • 185
              ok i dont knw much abwt them so il post image of it on here and my soldering skills are ok
              • cactikid
                • 12017
                has anybody fixed them by soldering bits in,would think a board be the safer option.
                • ekkostar
                  • 44
                  You'd not be a man, you'd be a fool trying to solder caps on a 240v psu if you don't know what you are doing or know how to discharge some of them.
                  Just order a new PSU and be done with it.
                  • asad5150
                    • Oct 2008
                    • 185
                    im going to give to my mate who know fixed psu he may be able to fix it if not then il get a new psu.
                    • asad5150
                      • Oct 2008
                      • 185
                      also if i get it fixed or buy a new psu will it blow out again?
                      • cactikid
                        • 12017
                        quite possible as the build in clone boxes lately is a disgrace.
                        • asad5150
                          • Oct 2008
                          • 185
                          this is pics of the psu
                          • asad5150
                            • Oct 2008
                            • 185
                            got new psu put it in and box works now. any ideas how i can make the new psu last longer. if i switch box off when not watching will dat help?
                            • lombard
                              • 793
                              that would be just luck, ya put it on standby when not used would be good idea, or even put it on deep standby, should be able to still record
