oscam/cccam help please
  • madmanuk
    • 202
    hi lads can anyone help me set my new vu+duo up to run oscam/cccam please i got files in there but can't get it to work, I thinks its running black hole image.
  • mdt
    • 3034
    why not just run oscam,regards mdt
    • madmanuk
      • 202
      what you meen mate in the box it say cam is oscam/cccam but the server and configs are not the same as my dm500 that running oscam/cccam othewise i think i may have beable to do it my self.
      • madmanuk
        • 202
        This is the config and server files,What should i change lads.
        thanks.Config
        #automatic build for BlackHole
        [global]
        #nice = -20..+20
        # system priority, default:system given
        Nice = -1
        saveinithistory = 1
        #logfile = filename|/dev/null|/dev/tty|syslog
        # logging target, default: /var/log/oscam.log
        #LogFile = /dev/tty
        LogFile = stdout
        #logfile = /var/log/oscam.log
        #log file for user logging, default:none
        #usrfile = /var/log/oscamuser.log
        #maxlogsize = kbytes
        # max log file size, default:10
        maxlogsize =10
        #waitforcards = 0|1
        # 1 = wait for local SCs on startup before opening network ports,
        # default:0
        #waitforcards = 0
        #pidfile = filename
        # PID file, default:no PID file
        pidfile = /var/run/oscam.pid
        ClientTimeout = 5
        CacheDelay = 120
        [webif]
        httpallowed = 127.0.0.1,192.168.0.2-192.168.0.100,192.168.1.2-192.168.1.100 # Or SET your House Lan
        httpport = 8080
        httpuser =
        httppwd =
        #httpscript =
        httprefresh = 5
        httphideidleclients = 0
        [newcamd]
        Key = 0102030405060708091011121314
        Port = 50000@093b:0000
        Port = 50001@0919:0000
        Server
        [reader]
        Label = Slot0
        Protocol = internal
        Device = /dev/sci0
        #mhz = 600
        #Fallback = 0
        Group = 1
        EMMCache = 1,3,2
        boxid = 12345678
        #Services = !sport,!calcio,!milan,!juventus,!inter,!roma,!moto tv,!caccia_e_pesca,!classica,!prima_fila,!contotv
