Zyxel PLA4201 500Mbps Mini Powerline Ethernet
  • Bumsrus
    • Apr 2012
    • 65
    Anyone using these that can provide some good feedback?
    Apparently they can provide 60% performance improvements compared with 200mbs
    I currently use Technomate 85mbps Homeplugs, do you guys think I will notice much differences?
  • Bumsrus
    • Apr 2012
    • 65
    Balls posted in wrong section.
      New balls Please
      • gsmtech
        • 264
        What are you doing with them ? If its just for cs key exchange then its. Waste as that uses a negligible amount of bandwidth. For transferring large file and streaming full HD content you may see benefit. Also depends on the quality of your household electrical cabling. If you want proper performance just hardwire your house with cat 5e or 6 network cabling.
        Sent from my Nexus 7 using Tapatalk 2
        • Bumsrus
          • Apr 2012
          • 65
          The only streaming i do, is streaming of 1channel, and its unwatchable because of the stuttering. I take it, that's due to my crappy 2.5mb broadband and these home plugs will not help?
            2.5mb should be adequate for the 1channel plugin as it does not carry anything in HD so SD should be fine
            • Bumsrus
              • Apr 2012
              • 65
              that makes me wonder why its so slow then.
