Duo wont flash via USB..
  • micflair
    • 275
    Hey guys and gals. Picked up a clone duo this week. Its come out of the box with Blackhole 1.7.2 installed on it, but wanted to give the latest clone safe Vix image a go as I hear its more user friendly as such.
    Im trying to flash via USB, I have put the image files in vuplus/duo but the box just boots to blackhole when I put the stick in the front usb slot. Is there something else I should be doing here?
    I thought it might be the stick but it works fine with my pc's etc, also the duo recognises it when I have it in there for crossepg etc so Im a bit puzzled.
    Any thoughts?
  • potrobber
    • Mar 2010
    • 493
    it should work ok with vuplus file on root of usb stick put it in front usb and power on it should then say reading usb on front display
    try downloading image from somewhere else and see what happens
    i have done lots of clones and not had one not flash doing it the above way
    • benny/9
      • 1964
      Any thoughts?
      have you tried formating the stick to fat32
      also i have read dream and vu boxes dont work
      with some usb sticks, but when changed everything
      works, have you got anouther stick to try
      Please Read Carefully!
      • micflair
        • 275
        Cheers guys. Tried with just putting the 3 files in the root, still nothing.
        Reformatted the drive to fat32 again, still nothing.
        Now my extra problem is this - the actual lcd display has taken a bang (or is a friday afternoon model) and it doesn't work. A pin has come loose on the display itself and cant be resoldered. I shouldn't imagine this would effect the USB port though. So I get nothing on the display, it just boots to the blackhole image as I cant see what the display could or should read! Does it automatically flash the image or do you have to press something? If I have to press something then I wont know as I cant see jack on the display.. haha
        • potrobber
          • Mar 2010
          • 493
          hi it will just load from the usb stick what its powered on if you can not see display leave it for about 5 mins if it does flash for you before powering of
          whan you say just the 3 files what way are you putting this on stick?
          when i put image on stick i open the rar file and just load the vuplus file on its own it has the
          files in it
          are you opening this and putting them on stick in separate files ? it will not work this way
          • benny/9
            • 1964
            as potrobber has aready told you it wont flash if
            your opening the vuplus folder and the duo folder
            and taking the files out and then putting them on your
            usb stick,? if you are then it wont flash the box
            you dont open the vuplus folder you send that to the
            usb stick. then it loads the vuplus folder the duo folder
            and the files then the vu will open these two folders and flash
            the box for you.
            • micflair
              • 275
              Nah I aint doing that, the files are there in the vuplus/duo folder. Im just unraring the file straight to the stick.
              Just picked up a new stick now, lets give it a whirl..
              • potrobber
                • Mar 2010
                • 493
                can you pm a link to the image and i will try it for you to check its ok
                have you tried any other images
                • micflair
                  • 275
                  Sorted.
                  The new stick cured all the problems first time, very strange that it wouldnt like the other stick! ah well!
                  Thanks for your help guys.
                  • cactikid
                    • 12017
                    well known to have a load of different sticks to try.
