VU+ Duo not working after fitting a HDD
  • Melio
    • Jan 2012
    Guys, I have VU+ Duo (original) and I just fitting a HDD in it (1TB Western digital 3.5). Plug the cables in and fixed it to the caddy. I went to plug it in and now the box won't turn on, no power at all. Any ideas?
  • DOUGALMCD
    • May 2011
    • 3229
    Did you format hdd before fitting? Disconnect again then try. Did you make sure all cables are pushed home? With electicity off.
    • vicentium
      • Aug 2011
      • 16
      Does your HHD have external power supply? If not perhaps it drag too much current from USB. In this case use a USB hub with external power supply to connect the HHD.
      • Melio
        • Jan 2012
        Sorted. The Plug connector for the power is a really tight fit and it's pushed the pin inside so wasn't connect. Took the connector out and pushed it back in all fine. Just set Jaws 2 to record so I can watch it later
