only one tuner works
  • jimmynewbie
    • Nov 2010
    • 19
    in my VU+Duo only one tuner works .I am using BH image and read somewhere about changing image to get it to work . I have BH experimental 10 April 2011 and I think that may be the problem . I tried various config .The tuners are being detected .I have also switched cables tried all cables from Quad LNB.
  • mdt
    • 3034
    have you activated the second tuner in the menu,s? regards mdt
    • jimmynewbie
      • Nov 2010
      • 19
      duff tuner
      Both tuners are set up exactly the same simple config one sat
      • cactikid
        • 12017
        do you have 2 sat cables connected?
        • the goat
          • Mar 2010
          • 122
          I've read that some tuner probelms can be fixed by using image Blackhole 1.6.6 or below, or vix 2.3
          • alec
            • 345
            You need to give more details, for example:
            Are you using 2 feeds and have you tried one lead to both tuners in turn. I have two feeds on on a motorised system . Tuner A is advanced and Turner B is on second cable Motorised LNB Turner A
            • seamouse
              • 287
              only one tuner works at a time unless ur recording on the other one
              as i used a sat finder the other day, on turner a was working but on turner b it wasnt ( on another sat ) changed to 13 e on tuner b, beep beep
              MY POSTS AND ANY PM`S ARE PURELY FOR EDUCATIONAL AND LEARNING PURPOSES
              I AM FULLY RESPONSIBLE FOR MY OWN POSTS, MY POSTS ARE NOT CONDONED, MODERATED OR AUTHORISED BY ANY MEMBER OF STAFF ON THIS SITE AND I TAKE FULL RESPONSIBILITY FOR ANY CONTENT CONTAINED IN MY POSTS OR LINKED TO EXTERNALLY.
              • manster
                • Sep 2009
                • 229
                Tuner B needs to be set as " EQUAL TO TUNER A " in the tuner option.
                • hitman07
                  • 171
                  can i watch one channel and record another if there is only one satellite feed cable going into the box? or do i need two feeds?
                  TIA
