Vu+ duo satellite setup
  • npk
    • May 2011
    • 7
    I have read all the tutorials and so far I have everything up and running using vix oe3 on my clone duo. I am stuck on how to put other satellites on my sat setup. I don't have any other options in my sat Config only 28.2, all sat1, all sat2, all sat3, etc etc. anyone know how to add 19e etcetc on my motorised dish that took 2hours to do from scratch
  • mdt
    • 3034
    change your settings in the menu/set-up/service searching/tuner config to simple/positioner and enter your long/lat details.you may want to add a settings list from @catseye or @vhannibal using dbedit and update the satellites.xml file. regards mdt
    • npk
      • May 2011
      • 7
      I have added the long lat in but I can not see any other sat apart from 28.2E
      • npk
        • May 2011
        • 7
        I have my own dbedit list from my dm7020 that I have entered, I just need to know how to add other sats
        • npk
          • May 2011
          • 7
          Done it after reflashing, I now have option to change from lnb1,2,3 etc to assign to different sats. The only thing left is to get my cam to see my card as at the moment it says card not inserted, I have the /dev/scsi0 in but still not seen
            mate you own a DM7020 which i assume is an Enigma1 version if so its not that different from Enigma2 apart from different folder locations.
            Not to sound to pedantic but obviously in your 18 month stint here with 8 posts you have still a lot of tutorial reading ahead of you, Because everything you have asked so far has been answered on numerous occasions and can be found by using the search facility
            • npk
              • May 2011
              • 7
              I did search, found the boxkey info added it for top and bottom slot, I have read lots and when I mean lots I mean lots of info. I may have only 8 posts but this is due to me reading the pots on here to find out any answers I have.
