hi all, my vu+duo has been good for about 3 months running oscam/cccam but today oscam won't work,i get all channels apart from movies sport and hd,I have replace the oscam files but it will not kick in, can anyone help me please. Running Black Hole also errors saying , Error processing ecm for caid 0963, srvid 2EF4 (servicename:
oscam/cccam help on a vu+duo
this isnt really a fix but a workaround that might work.. try removing the ecm whitelist if you have one. regards mdtDM800HDSE SIM 2.10. SSL84D OPEN-ATV ORBITAL 80CM/DARK MOTOR/IBU/53E-30W -
thanks mate but i don't think i got one,Heres somthin els i hope you can help with mate, Befor it went on the blink oscam would only work if i had a sat feed going in to the box,If i unplugged the feed the i would loose sports and movies and hd channels do you know why i have to have the sat feed in,It only needs it for the vu+duo.
thanks mateComment
maybe you have it set up to recieve the EMM,s from the sat feed and not from your peers... im no expert in this m8 and have a lot to learn myself. why dont you switch to oscam on its own as i use it with very few issues that are usually broadcaster related and fixed in no time. regards mdtthanks mate but i don't think i got one,Heres somthin els i hope you can help with mate, Befor it went on the blink oscam would only work if i had a sat feed going in to the box,If i unplugged the feed the i would loose sports and movies and hd channels do you know why i have to have the sat feed in,It only needs it for the vu+duo.
thanks mateDM800HDSE SIM 2.10. SSL84D OPEN-ATV ORBITAL 80CM/DARK MOTOR/IBU/53E-30WComment
i can send you everything you need to set oscam up on you duo using blackhole image all you will need to change is your ports,peers ect. pm me your e-mail addy and ill send them over. regards mdtDM800HDSE SIM 2.10. SSL84D OPEN-ATV ORBITAL 80CM/DARK MOTOR/IBU/53E-30WComment
