is there anyway to get a 3.5" to work in a clone duo?
  • stevo88
    • Oct 2012
    • 70
    is there anyway to get a 3.5" hdd to work in a clone duo?
    i have a seagate 320GB thats out of a sky hd box.
    thanks.
  • dell_xps
    • 2558
    Is the one from a sky box not an ide ?, whereas a Vu takes a sata hard drive, you would need a ide to serial ata convertor, there on Ebay for a few quid, and I believe it works.
    HTH
    • stevo88
      • Oct 2012
      • 70
      no its a sata, all connections fit perfectly
      • Rodbouy
        • Jul 2010
        • 1320
        What is the exact problem?
        What image are you running?
        Is it just not recording?
        • dell_xps
          • 2558
          What exactly is the problem ?, have you formatted it ?
          • alonso
            • 47
            I stuck a 320gb drive in my clone thats from a skybox, working great! (Blackhole 1.7.3)
            • stevo88
              • Oct 2012
              • 70
              i havent done anything with it just took it out the sky box and put it in the duo? do i need to format?
              alonso did you format before putting in the duo?
              • dell_xps
                • 2558
                Initialize it !!
                • alonso
                  • 47
                  No I didnt format it, just stuck it in mate then initialised it then mounted it
                  • portbhoy
                    • 717
                    For info see http://www.digital-kaos.co.uk/forums...starts-303889/
                    • Rodbouy
                      • Jul 2010
                      • 1320
                      For BH images you need to initialize then mount.
                      If using PLi you need to initialize also but should auto mount.
                      If it does other aspects ie store picons but does not record, then add move dir to hdd and it will then will recording.
                        Just for future reference the Sky HD hard drives should not need formatting as the Sky HD receivers run a form of linux themselves, so as already stated just stick the hard drive in and mount via the blue button i have not yet had to initialise any Sky HD drive in any Linux reciever
