Duo image change BH to Vix (Clone) Fresh/Clean Install?
  • dekd1
    • Dec 2010
    • 40
    Howdy,
    Had my clone for a week, thinks it's fab, but want to play now. It's come loaded with BH 1.7.2 on it and it's ok, but I fancy a change to Vix. I see that there 2.4.155 seems to be the favoured vix image but I also see some 3.0 (Clonesafe images) for the moment, I'm happy to try the 2.4......
    I'm cutting some corners though and looking to use a backup to save a little time - oscamtocccam configured etc.
    I've got one image I want to try and it states that a fresh/clean install is required.
    Starts looking and have to admit a temp defeat
    Would someone with more knowhow than me be kind enough to give a pointer or two on steps to go from BH to Vix and in particular, use a backup image.
    Thanks in advance all..... It's Friday
    You just flash the image from USB and that is it.
    • dekd1
      • Dec 2010
      • 40
      Cheers ! Well, that's me feeling like a dafty
      Threw me a little really, fresh/clean... was thinking there is something a little different to the norm - a la must be with serial cable not usb etc.
      Appreciate the quick reply, thanks ! Still partly wondering why there is a big note on a readme saying if you havn't done a fresh/clean install on this image - you must do so.
      Your reply is good enough for me though.
      Have a great weekend pal !
      Time to play.........
      • RuberDuck
        • 1724
        A fresh or clean install basically just means flash the image rather than a online update, and dont restore settings.
        This is recommended because often things change so much between versions that settings and plugins must be setup again or they would cause problems.
        • dekd1
          • Dec 2010
          • 40
          cheers to you both !
          "This is recommended because often things change so much between versions that settings and plugins must be setup again or they would cause problems." Crystal clear now
