vu duo update problem
  • g20
    • Nov 2012
    • 6
    hi all , need a little help re black hole updating , problem is i cant get the box to boot after flashing with anything after bhole 1.7.6 .it updates the box tells me to remove usb restart and then it just sits on start up , any ideas cheers
  • digicon
    • 8261
    Assuming its a clone then you can only use Blackhole images up to 1.7.5 anything after will not let the box boot due to drivers. If you have an original then it should be ok with any image.
    • g20
      • Nov 2012
      • 6
      checked it out and its not a clone , cost 340
      • digicon
        • 8261
        Try re-downloading the image file again just incase the one you have is corrupted some how and then try again.
        • g20
          • Nov 2012
          • 6
          ok guys ive sorted it , i down loaded the latest blackhole from a different site and it worked first time, file must be at fault cheers for all sugestions
          • mdt
            • 3034
            in future for blackhole images go direct to the source...
            w**.vuplus-community.net
            regards mdt
