need help with cccam
  • manutd4life
    • 132
    right i have followed the tut in the sticky, but i cant get the $ channels to work. got cccam 2.1.4 installed and vix image. any one had this problem and solved it. i have the cfg file in /etc.
    cheers
  • digicon
    • 8261
    cheers
    First did you install the Vix specific cam and secondly just curious as to why you would choose CCcam 2.1.4
    • manutd4life
      • 132
      my mate has gave me this box to try and sort mate, how would i find the first question out? as for the 2.1.4 he was trying diff cams as none would work
      cheers
      • manutd4life
        • 132
        sorry i installed this, enigma2-plugin-cams-cccam.2.2.1_1.0-r0_mipsel.ipk
        • digicon
          • 8261
          The Vix cams can be found here
          http://www.4shared.com/dir/wnyHV50A/VIX_CAMS.html
          maybe better trying one of these first before anything else
          Last edited by satsmo; 5 December, 2012, 23:26. Reason: Coded link, please do so in future especially to off site upload servers containg CAMs
          • manutd4life
            • 132
            The Vix cams can be found here *******maybe better trying one of these first before anything else
            cheers mate, i dont think you seen my previous post, you reckon i should try all the cam versions?
            • digicon
              • 8261
              No if your only trying CCcam then download one from the site and test it
              • dell_xps
                • 2558
                Have you enabled it in the menu ?
                • manutd4life
                  • 132
                  yes mate
                  does it go here? /var/volatile/tmp/
                  • digicon
                    • 8261
                    When he says 'Enabled' it he means have you activated it in the cam menu
                    • manutd4life
                      • 132
                      pretty sure i did, i pressed ok on it and i had to wait for it load. then i pressed the blue button on another menu to malke sure it was enabled and it had the tick in the box
                      • digicon
                        • 8261
                        That's correct it should be good to go then
                        • manutd4life
                          • 132
                          im trying to move the vix cam into tmp folder but it keeps saying move failure. and i have the cccam.cfg in etc, is that correct? do i need to edit that depending what version vix cam i have?
                          cheers
                          • pongo snodgrass
                            • 178
                            here try this cccam2.3.0 its in .ipk form....extract and ftp to tmp folder then install it via the addons panel..
                            Last edited by satsmo; 5 December, 2012, 23:28. Reason: Removed direct upload to our server
                            • manutd4life
                              • 132
                              getting the same thing mate
