Has anyone been able to change v2 chip on the duo to a v3, think they can be bought for a few dollars from china if you have the skills to solder it on...
Change vu duo from v2 to v3
i wouldnt attempt it unless really skilled in electronics repair. the boxs run fine on the earlier kernel/driver based images and unless the image update is absolutley needed i wouldnt bother personally,regards mdtDM800HDSE SIM 2.10. SSL84D OPEN-ATV ORBITAL 80CM/DARK MOTOR/IBU/53E-30WComment
I am sure that you will not get away with just replacing the v2 chip for a 3 as the memory wright speed is faster on the v3 so that is 2 more chips to replace.
Hope you have a microscope and a very steady hand.
Good look!Last edited by reddishd; 20 December, 2012, 03:26.get on your or off your box, with a bong!
At least once a month,
You only live once!Comment
No to mention that they don't actually do anything as yet.
Still waiting for the update which will allow v3 boxes to use the latest images. Ferrari team are sh**Comment
It's not worth upgrading to version 3 at the moment. My cousin brought one and the tune failed issue is more frequent. Stick with version 2, it is a bit more stable.Comment
