Hi All,
I've not posted much on this forum but have been doing a lot of reading (and have looked at other threads similar to this one!)
I've just received my Vu duo V3 clone from china (I'm in the UK) I did a lot of reading while waiting for it to turn up so thought I was ready.
First thing I did was flash it via usb on the front port with version 3.0.204 of vix (thought it was the latest obe but since found out there are more current versions).
After a few tries it loaded and flashed as it should, but then wouldn't boot, it continually froze on 'Starting'.
Now, one thing to mention is that I didn't try starting it with the shipped image, so don't know if it worked properly from the start. I had a HDD installed, so took it out, tried booting again and got the same result.
After a bit more reading I flashed with a different image and usb stick (kingston 2GB), the image was vix 2.3.153 which was recommended in another forum.
This eventually flashed (for some reason wouldnt pick up front usb but worked with rear slot) and started up ok.
I started setting up the box, got to the scanning part, started scanning and after a few minutes rebooted on its own, and froze once again in starting.
I've tried reflashing many times now, sometimes it picks up the front port, sometimes not.
I'm wondering if its overheating as the rear fan isn't on (doesn't seem to be too warm) also the heatsink on the cpu is pretty flimsy.
I'm thinking its a DOA box, but wondered if I've done anything to it, like flashing with the newer vix image?
Any help or advice would be appreciated!
regards mdt
